XLR-SAM
To All XLR Owners,
Asking for guidance and help. I took my XLR into the dealership because it had a small coolant leak that I could not determine where it was coming from. As I drove into the dealership, the small T-Connector to one of the hoses broke, and through the help of the users on this forum, i was able find a brass T connector to solve that problem. Their was an engine code, I believe it was a P308 that indicated there was an engine misfire, and the dealership indicated that they needed to perform a head check to the heads on the vehicle. As it turned out, they indicated that i had a blown head gasket, and the dealership was not setup to perform this type of work. They indicated that the bolts may have been stretched, and the head would probably need to be drilled out, have inserted brass ring, to replace with new bolts. Bottom line, it's a huge job, and trying to figure out what my options are to either have this rebuilt or maybe have a new engine/rebuilt engine dropped in as a possible solution. The Dealership indicated that these type of jobs are very specialized, and were recommending to find a shop that rebuilds racing engines. Just wondering if anyone has encountered this problem, and what solutions i have to repair my Vehicle. Looking for qualified shops to contact to either work on this motor, or find a place that sells a rebuilt 4.6L NorthStar engine to replace the current motor I have. I would appreciate any advice given since my may have occurred to other XLR owners.
I live in California, Rancho Cucamonga. San Bernardino County,
Thank you,
Sergio
Thank you,
Sergio
