Cadillac Tech
Engine Mechanical - 4.6L (LH2) | Specifications | Document ID: 822440
Engine Mechanical Specifications
General
- Engine Type
- Displacement
279 cu in
- RPO
- VIN
- Bore
3.661 in
- Stroke
3.3071 in
- Compression Ratio
- Engine Compression Test
140-170 psi
- Firing Order
- Spark Plug Gap
0.0500 in
Lubrication System
- Oil Capacity - with New Dry Oil Filter
8.0 Quarts
- Oil Capacity - without Oil Filter Change
7.5 Quarts
- Oil Pressure - Minimum @ Idle
5 psi
- Oil Pressure - Minimum @ 2,000 RPM
35 psi
