Cadillac Tech
2006 Cadillac XLR | XLR (VIN Y) Service Manual | Transmission/Transaxle | Automatic Transmission - 6L80E | Specifications | Document ID: 1593598
Transmission General Specifications
Name
6L80
RPO Codes
MYC
Production Location
Ypsilanti, Michigan (USA)
Transmission Drive
Rear Wheel Drive
1st Gear Ratio
4.027
2nd Gear Ratio
2.364
3rd Gear Ratio
1.532
4th Gear Ratio
1.152
5th Gear Ratio
0.852
6th Gear Ratio
0.667
Reverse
3.064
Torque Converter Size - Diameter of Torque Converter Turbine
258/300 mm
Pressure Taps
Line Pressure
Transmission Fluid Type
Dexron VI
Transmission Type: 6
Six Forward Gears
Transmission Type: L
Longitude Mount
Transmission Type: 80
Product Series
Position Quadrant
P, R, N, D, S (some models)
Case Material
Die Cast Aluminum
Transmission Net Weight
96.7 kg (213.2 lb)
Maximum Trailer Towing Capacity
N/A
