Bluestar bluetooth
Bimota fan
So Cal
2006 Black XLR-V
The only negative I have heard about the Bluestar unit is it will drain the battery if something hangs up and it does not disconnect. Has anyone tried hooking up the unit to an ignition switched power source so that will disconnect when the car is turned off?
Steve
Steve
I was supposed to do it this winter, but got lazy. Maybe in the next month or so when I get it back from Florida.
does it work?
I've just started checking on these things, on star is crazy prices and you have to buy minutes from them.
Fill a newbi in on this.
Is it plug and play?
Has anyone tried it?
Does it work and if so, how well?
Any and all input would be appreciated.
Be sure to check out actual rear wheel HP increases I posted earlier installing a cold air intake and Corsa exhaust, good increases.
