Drivers door is dead?
nicholas.brady
Florida
So, drivers door just isn't working. Won't open, window won't roll down, mirror not working. But the drivers door switch will control the passenger window and mirror just fine, and the passenger door opens with no problems. Any thoughts?
After you've checked fuse 34 under the hood fuse box, (aka, the UBEC) which is probably good, the DDM Driver's Door Module) comes to mind. It controls the driver's door latch switches and window. If the driver's door is open, do you get a LEFT DOOR AJAR indication? The DDM sends that signal to the IPC (Instrument Panel Cluster) via the BCM (Body Control Module.) If not, very likely a faulty DDM.
CCC
