Engine Bolts
RubyRod
Florida
2005 Crimson Pearl
So I had to replace the Water Pump on my car and I got a shock when I discovered that the housing mounting bolts are high carbon steel. After 20 years I would have expected steel bolts to have fused solid to the aluminum engine parts but not so. The bolts can't be bare steel or they would have fused to the aluminum. They are not stainless either. They must be coated with something to prevent corrosion from fusing them to the aluminum. Does anyone know what the engine bolts are coated with? I'm sure at some point I'll have to replace one of the steel bolts somewhere on the engine and I'd like to know what type of coating I'll need to prevent corrosion.
I think I've discovered what the coating is on these engine bolts. It's a patented process called Dacromet. Unfortunately I haven't found a source for these bolts except the Auto Dealers. Apparently the patent costs are too excessive for these to be available through hardware stores or auto parts stores.
