knight rider
I have spent considerable time reading recommendations on the site and greatly appreciate all of the input that is available. I'm hoping to obtain some verification from the community on what is needed to resolve my problem.
The other day after lowering the top for the first time this season there were no problems in lowering but when I tried to put the top up I received the "TOP MOTOR OVERTEMP" message and the process terminated. When I took it into the local dealer they provided me with the analysis listed below along with an estimate of $4656 for repairs. My concern, aside from the price, is that if the top down button is pushed shouldn't the first two steps in the sequence take place before it fails even if the hydraulic pump has failed? Additionally, doesn't it seem unlikely that the tonneau sensor, liftgate lock and the pump would fail simultaneously? Admittedly, I am not the most technical person but I want to at least understand my options before considering a costly repair like this.
Repair Analysis:
- Rear Tonneau position sensor times two needed
- Pump motor assembly and oil needed
- Lift gate lock needed
- B3669 Folding rear tap signal open
- B1297 trunk unlatched. Signal current lid pull down
- B3670 pump motor temp sensor circuit checked and performed TAP, check for codes B3669-folding tap rear deck lid, and rear tanneau posture, open.
- B1297 - trunk unlatched signal. circuit lid pull down
- B3670 - pump motor temp sensor circuit fault, tested, from module, para out when command on 2 of poss module also.
Repair Analysis:
