Hoping someone can help me navigate this one. Recently my check engine light came on. According to the code I had a bad mass air flow sensor. Bought a new OEM one and replaced it. Same problem. Now I'm getting the following codes: P1101 - Mass air flow sensor out of self test range, P0174, Fuel trim system lean bank 2, P0171, Fuel trim system lean bank 1, P0101, Mass air flow sensor performance, and P0068, MAP/MAF Throttle Position correlation. The car isn't running right, and at low speed/low throttle it's pinging.
I Don't want to go down the rabbit hole on this one. I'd prefer to do the work myself unless it's something major. Unfortunately, my local Cadillac dealer's service department is inept at best. I don't say that out of spite, they really do not have a clue what to do on an XLR which they've shown me several times.
Any idea what I should check/replace in any particular order? I.E., I don't want to replace fuel pumps to find the problem was an O2 sensor.
Thanks in advance!
Thanks in advance!
