Help! Gasket part numbers
Batmobile
Saudi Arabia
2007 Raven Black XLR-V
Hey XLR people! Need your help with identifying some part numbers for accuracy.
Doing engine bushings, change all hoses, and since the supercharger has come out, gaskets!
As you can see from the picture below, oil residue coming out of the engine covers and baked there.
Those are the engine cover gaskets, but which are the other ones below?
Thanks mickeytee,
So for reference..
R, Cylinder Head Gasket12613034
L, Cylinder Head Gasket12613033
R, Valve Cover Gasket12576394
L, Valve Cover Gasket12576395
Rear rubber seal for S/C intake12584008
S/C Gasket12590737
Unfortunately the rear air intake boot is discontinued, no longer manufactured part no. (12584008).
What's the best alternative?
best be very careful with it and not damage it .its just a rubber boot and most likely some aftermarket hose will fit . Might want to pull the power steering pump pulley off and inspect it. the pulley insert with the splines that go over the pump wears and if loose on the pump will strip out the pump. I have parts for it but they are rather expensive for the pump if you let it go too long before pulley replacement.
I would like to change the oil in my supercharger on my 06v but the gaskets are discontinued the link above says not avalible. Ive read about sucking the fluid out with supercharger on the vehicle is this possible? My 06 has 70k miles should I change the oil in the supercharger? I read there is a vacuum line under the the supercharger that wears a hole in it also should I be concerned about that?
Not sure about the vacuum line. I am close to having a better and cheaper intake gasket that the ones you can get from northstar performance. . not sure about the line you are adking about. Ill have to look into that. GM does not reccomend changing the oil. Just the coolant fluid.
