Help using Tech 2
rheavn
South Dakota
'09 Platinum #787
I get 2 DTCs on the "EBCM" How do I find what the codes are?
Learning how to use my Tech 2........................................................
Found the two codes on the EBCM. They are for the right front and right rear wheel speed sensors--C0040 & C0050. There was also a stored U2108 code, "Lost communication with EBCM" but on the last test it passed.
delete them and see if they come back. speed sensors can fail from debris blocking the signal and then they later work.
Those two DTCs will not delete and I continue to get the ABS & T/C light.
they may be faulty then. they of course are what has the traction light on. they are not expensive and not hard to replace.
Thanks for the reply! Is it the right side wheel sensors that may be bad? Any chance you have part numbers?
