I purchased new wheels that did not come with centering rings and are meant to fit a C6 Corvette. I checked the specs beforehand, including the bores, and an XLR matches a C6.
Today I went to get the new tires mounted and the tire dealer is having problems with balance (road force). We check the wheels, with the tires mounted, and the radial run out is about .028". I called the manufacturer, Factory Reproductions, and they say the absolute max. is .020" but should be measured using a spider and a flat plate so that location is done from the lugs??!
A call to a different retailer...... they say they supply centering rings. This tells me that they are hub concentric and measuring the run out should be done off of the hub taper.
A lot of different stories. Can anyone with aftermarket wheels tell me what they know? Did you use centering rings?
TIA
TIA
