LarryW143
I know this has probably been covered but I have a leak in the hydraulic top system. The system leaks about 15CC of fluid per cycle. With that much fluid you would think it wouldn't be hard to find. Theres one area i haven't been able to access and thats the bottom of the pump itself. That area seems to be damp, but is difficult to see. 3 questions. Is it common for a pump to blow a seal? The pump itself is functioning fine. Is there a published procedure to remove this pump? Are there any issues with TopHydraulics?
Larry
Larry
