Inside interior driver side light
al williams
memphis tn
2004 black xlr
I have light on the driver side just hanging ( under the dash ) do anyone know the proper name and p/n so i my oder the part ?:dunno: Also The steering effort actuator had two wires ...one is red and one is black.The wires ( from the square box mounted on the back of the ABS system ) that leading to the steering effort actuator... one is white and one is light brown ( both of these wires has power ) which wire connect to red and which connect to the black ?:dunno:
Have no clue which lamp you're talking about, when does it come on?
You may want to invest in a service manual.
Here is the panel itself, I guess it depends on of the courtesy light lens is broken or the panel it clips into is broken.
[QUO TThaTE=Fireduck;57186]
Here is the panel itself, I guess it depends on of the courtesy light lens is broken or the panel it clips into is broken. Thanks Fireduck.... i have the light len it should just snap in !!!:wave:
Sent from my iPhone using Tapatalk[/QUOTE]
