arv09
http://www.obdiiscanner.com/professi...gm-tech-2.html
I bought mine from a web sight that I found on the another XLR forum. I listed it above. It came with everything you need for all the XLRs made to date. I've used mine to clear some codes on a friend XLR 05. He was having trouble with the trunk not opening. Then there was an issue with the top stopping in mid operation. We did a relearn on the top and cured both problems. I have hooked it up to my 06 V to check a few things. They also say you can take a reading on your top operations periodicly to check if a sensor is going bad. I haven't had time to check that out yet. It is amazing what this scanner can do and tell you about the operation of the car. It does come with the updated software and operating disc. I think with this tech 2 and the service manuals you can do a lot yourself.
V Happy
arv09
This unit comes with two Bosch disks. I am running windows 7 and one would work on my computer. The other one would (TIS 2000) not work on my computer. This is the users manual which is pretty lengthy but helps. I hope all works out for you.
V Happy
