Steve Lee
I installed a new lower hinge, and adjusted the door as perfect as can be. All of the lines between the door, front fender, and quarter panel are good. The striker on the door is in perfect alignment with it's sister part on the rear quarter. (I checked it by putting a piece of masking tape on the quarter panel, and put a horizontal mark on that tape in line with the part on the door.) The door opens very nicely from the inside when the release button is pushed, (It actully "pops" open about 10 inches or so) but when I open it from the outside, it seems like there is a VERY, VERY SLIGHT drag felt, I.E. It doesn't pop open like it does from the inside. I suspect the latch on the quarter panel may be a little worn. I had removed the outside release pads on both doors several months ago and cleaned the circuit pads, because the right one didn't work, so while I was at it I did the driver's side to as a precaution, and they both work. Any and all comments would be appreciated!!!!
