WB6BBZ
- Joined
- Mar 25, 2010
- Messages
- 268
- My XLR/V(s)
- 2006 #165 of 250 Limited Edition Star Black Metallic
The ACC was removed from the V series to make room for additional coolers.
The adaptive volume control is a setting on the unit that can be turned on and off at will.
A non-dealer modification is required to be able to play DVD's or change NAV settings while moving. It is documented on some other threads here.
Not on mine, my passenger or I can change settings on my STOCK SYSTEM while traveling at highway speeds! It's all done by Touch Screen control, no physical mods to the system required.
I wrote an addition to a thread about this awhile back, I can not remember who started the thread nor what the title was but GP, you should be able to do the same with your Base 05 as it was something that was supposed to work on the 04 and 05s only and I found out it works on my 06 also because it came off the assembly line in late 05.
Which means that my system was an 05 upgrade over the 04 but not an upgrade of the 05. IMHO!
