galen
Has anyone tried the wood interior trim kits available for our model car? I was looking at some of them and it dresses up the inside quite a bit. What do ya all think? Too much or it classes up the inside?
Has anyone tried the wood interior trim kits available for our model car? I was looking at some of them and it dresses up the inside quite a bit. What do ya all think? Too much or it classes up the inside?![]()
Thanks Marc, that was quick. Did you have much trouble installing the pieces? It looks good. I think I'm going to get a kit. Your car is a lot like mine. You should try the Corsa exhaust. Big improvement on mine.
Thanks Marc. I will post a picture when I'm finished. Clark, as Marc said my console is also dented. Probably from the seatbelt being clicked in. I think that in its self looks worse. It was also a used car like Marc's. Bruce and I tried matching different pieces at BG11 but they just didn't match well. I will probably only use the console and maybe the door pieces. Thanks for the opinion.
I installed a wood dash kit about a year ago. I purchased my X pre-owned and the only blem on the entire car was a small dent or crease on the center console from something being dropped on it (maybe a cell phone). The easiest way to fix it I figured was with the wood kit. I originally used only the center console wood parts but then loved the way it looked so I ended up using most of the kit. Two other XLR owners have seen it in person and both liked the look. In fact both thought my 04 was newer because of the wood and 1 ordered it and also loves it. I personally like the wood that goes on the doors. It has the XLR lettering cut out of it and the interior color shows through it. When the doors are open it is pretty impressive. I have some photos posted on here somewhere but if you would like to see any let me know and I will add some to this thread. I think I paid around $200 and the self install was easy. Hope that helps.
Mark where did you purchased the wood trim for the XLR and how close is the color of the original wood? Tks for your help
