- Thread starter
- #21
QueLou
ITS FIXED!!!! SOLUTION, SOLUTION!!!!!
A BIG THANKS TO N2DEEP, HE TOLD ME I HAD SAME PROBLEM HE HAD. HE SAID CHECK THE GROUND ON THE DRIVER SIDE FUEL PUMP. THE FUEL PUMP HARNESS. I TOOK THE GROUND WIRE AND GROUNDED IT TO THE BODY OF THE CAR. MY X IS RIDING LIKE A CHAMP!!!
That post above didnt fix my problem. I ended up changing both fuel pumps with GM pumps, The o rimgs in the fuel lines were worn out, so I replaced the fuel lines, and I changed the tube that connects the two fuel pumps together in the center of the pumps. I also disconnected the ground wire off the body of the car and ran it the correct way, and Ive been riding every since. No Problems. ISSUE RESOLVED!!! If I can help any please call or text 8032690514.
