Hi Rob,
Just been a crazy summer and now it's on the way to 'winter', ugh! What has my spring and summer consisted of? (a) working to earn income, and (b) working on The 79' Eldorado (Hess and Eisenhart Conversion) Convertible that I bought in California in February. This, 'non stop'.  The Eldorado as you are aware, just sat and was almost not used having only 45K Original Miles on it. Had been purchased new by a member of The Getty Oil Family in California in 1979 from Restor Cadillac in Burlingame CA (Restor Cadillac is now a Toyota Dealership there). Body, interior, paint and cosmetic appearance is excellent. When I got it the car was in Palm Springs. When they 'sit' all the seals dry out and they start to leak, everywhere. I have 'temporarily' nicknamed it the Exxon Valdez.
So far have done the front timing cover gasket set and installed a Cloyes True (double) Roller timing chain set. New plugs and wires and dizzy cap and rotor, reset the timing. New oil pan gasket set. New rear main bearing seal, new transmission seals, new radiator (aluminum 4 row), new water pump, thermostat and housing, all new hoses, radiator and heater. New fan belts. New alternator. Oil change and filter. Flushed the fuel system and cleaned everything and repainted all mechanicals as required, as well as redoing others prior work in many instances that had not been done correctly.
 Go figure. Ex., someone (?) had at one point removed the flywheel shield and did not reinstall it. Just left it 'open'. Very dangerous! Found a NOS one in California. Now installed.
Doing the oil pan was loads of fun as they bolt the motor mounts through the front timing cover and the engine and trans must be unbolted and lifted, plus the passenger side CV Axle removed in order to pull the pan. Ugh. Now done
Next, I will disassemble the front suspension and install all new A-Arm Bushings, new sway bar bushings, check all ball joints, and take care of a few glitchy electrical issues. Already have replaced the power antenna motor, installed a new ignition switch, dimmer switch (disassemble the dash and drop the steering column). More fun.
Anyhow, you get the picture. Just amazing how stuff deteriorates just 'sitting' and drying out. Plastic switches, hoses and gaskets. Kaput.
Have kept 'Goldie' serviced and running and just a few minor things like replaced the gas hood supports as they got weak. Took her on a few local cruises here in Colorado. Start her weekly let her run and hold the brake while in gear to circulate trans fluid, etc. In two weeks we will do some top down 'canyon carving' through The Rockies on a trip to Paonia Colorado on The Western Slope (in the XLR). Will stay there for a few days for their 'Festival'.
I have told my wife that one cannot be a car collector with only two cars.
 This typically generates severe frowning and dirty looks. Have been thinking about a later model Jag XKR Convert, or a Porsche 928 ???? Then again, deep down, the hot rod bug for scary tire shredding power beckons.
I need to reconnect with several friends on the site as I have obviously been 'out of touch' and am feeling a certain amount of associated guilt.
Best, Charles
