Help! Clicking Noise
I'm not sure if we had the same noises but I tightened the axle nuts, changed the differential fluid and changed the front sway bar links, no more noise from the front or rear.
Could be any of the above...
plus the heat plate between the exhaust and torque-tube... there are like 50 small bolts holding in place, and they get lose over time... when the chassis twists (like low speed turns) you can hear the plate pop when it moves around... you can get to most of them without taking anything apart to tighten the - I put some locktight on all of my bolts and the problem hasn't returned since.
just something else to look at.
