Convertible Top drain
Steve O'
Tampa, FL
Just incase anyone hasn’t checked this, I’ve read that this little drain hole gets clogged with leaves and I had some in mine. Hard to reach so I used a leaf blower to clean it out. Worked well! Has anyone thought to make the hole bigger just in case? IMG_8716.JPGIMG_8727.JPG
yes enlarge hole.
can add an extra hole while you are under there, i did other corner.
can also add 2 holes to passenger side compartment.
do it from underneath with a drill.
while we are on this topic, 'doe anyone else notic that the cove panel that goes on top of the compartment doesnt lay flush?
it kind of is bumped up a bit by the reservoir ?
mine is that way.
and in the pics in this thread it looks to be the same ?
minor flaw, but annoying
Mine laid flush. You do have to push the upper part under the main carpet piece.
