XFireXLR
- Joined
- Sep 28, 2008
- Messages
- 762
- My XLR/V(s)
- 2006 Gold Mist Met. XLR
Recently the "Low Coolant" warning came on in the DIC, checked and topped off the coolant...no more warning in the DIC. About 2 weeks later the warning appears again, and I repeat the above. I noticed each time that the level in the resevoirwas getting lower and lower from the previous time. Put a piece of cardboard under the car to see if that will help decipher where the leak is, and it seemed to be right of center of the engine, in the area of the water pump. Took the car to my GM dealer, who has been servicing the car exclusively since I purchased it from them. The could not get me in for at least 2 weeks, and I needed the car fixed sooner than later. Took the car to a friends shop who I have known for years and he was able to fit me in the next day. They pressure checked the engine and stated that coolant was leaking from the “weep hole” on the water pump and it needed to be replaced. The repair cost me $506.00 (non GM water pump) parts and labor. Took the car home and the next morning went out to check the coolant level and it was seriously low and had a puddle of coolant in the same area of the cardboard, before the repair. Took the car back the next and the tech pressure checked the system 4 times and could find the leak. It seems that the leak would only appear when the engine was cold, and he requested that I leave car overnight, which I did. The next morning the tech stated that the heater bypass hose from the pump was leaking. The owner of the shop showed me the hose, and for some reason there were 3 clamps on the hose, 2 OEM GM clamps and one screw type clamp (see picture below). I now think the tech was either lazy, inept or both forgot he slide the clamp down to remove the water pump and upon reinstallation put a screw clamp on insteda of sliding the OEM clamp back up. And this may have created a needless repair and cost me more money. Picked the car up last Friday and drove straight home about 10 miles and parked it. Check the coolant level Saturday, Sunday and Monday and no leak and the coolant level in the resevoir was at the proper level. On Tuesday I had to run a few errands (about 40 miles in total), I check the coolant level and it was correct and no leaks. I also checked the level periodically while running errand and everything was good, but noticed that car was running a bit hotter than before the water pump and hose installation. Also now my headlight washers are not working, but were working prior to the water pump/hose repair ( I know they are useless, but I would still like them to work.) The vonly other work that has been done was a new power steering rack that was done at the dealership, no problems there. Any help or insight will be greatly appreciated.
Pictures of coolant level and leak on cardboard before repair.
Hose
Coolant level and cardboard after repair.
Hose
