Cadillac Tech
Engine Mechanical - 4.4L | Repair Instructions - On Vehicle | Document ID: 1672890
Supercharger Belt Replacement
Callout
Component Name
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .
Preliminary Procedures
Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement .
1
Supercharger Drive Belt
Tip
Engine Mechanical - 4.4L | Repair Instructions - On Vehicle | Document ID: 1683113
Water Pump and Generator Belt Replacement
Callout
Component Name
Fastener Tightening Specifications: Refer to Fastener Tightening Specifications .Preliminary Procedures
Water Pump and Generator Drive Belt
Tip
| Document ID: 1683144
Air Conditioning Compressor and Power Steering Pump Belt Replacement
Callout
Component NamePreliminary Procedures
Air Conditioner Drive Belt Tensioner Bolt
Notice: Refer to Fastener Notice in the Preface section.
Tip
Access this bolt from under the vehicle.
Tighten
25 N·m (18 lb ft)
2
Tighten
25 N·m (18 lb ft)
Tip
Access the bolt from under the vehicle.
3
Air Conditioner Drive Belt Tensioner Assembly
Tip
Air Conditioning and Power Steering Drive Belt
Tip
Callout
Component Name
1
Tip
• Rotate the tensioner in a clockwise direction.
• Ensure the drive belt is properly aligned and seated into the grooves of the accessory drive pulleys.
Callout
Component Name
- Remove the engine sight shield. Refer to Intake Manifold Sight Shield Replacement .
- Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement .
Tip
Callout
- Remove the air cleaner assembly. Refer to Air Cleaner Assembly Replacement . Remove the water pump and generator drive belt. Refer to Water Pump and Generator Belt Replacement . Remove the supercharger drive belt. Refer to Supercharger Belt Replacement .
- Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle .
Tip
Tighten
25 N·m (18 lb ft)
2
Tighten
25 N·m (18 lb ft)
Tip
3
Tip
• Rotate the tensioner in a clockwise direction during belt removal and installation.
• Relieve the tension, rotate the belt slack downward and remove the drive belt from the air conditioning compressor pulley.
• Use care not to pinch the belt between the tensioner pulley and the air conditioning compressor pulley.
• Remove the tensioner assembly in order to remove the drive belt from the vehicle.
4• Use care not to pinch the belt between the tensioner pulley and the air conditioning compressor pulley.
Tip
