lextoy
hi all, i am noticing my drivers side headlight moves when i turn. it moves far left for left hand turns, and a little bit right on right hand turns. then it settles back to straight position when going straight.
my passenger side light doesnt move ? i suspect it is supposed to perform as the drivers side does.
can anyone confirm?
also the passenger side seems to be aimed a bit towards the centerline of the car, not straight out like the drivers side, arent they both supposed to be pointing straight out when going straight?
last problem is the passenger side is aimed low, i need to adjust it up... what is the height we should use to aim the lights? manual says measure the low beam height at the "dot"
what dot, where is it, center of the light? side of it? can anyone describe its location? or tell me what height they used?
can anyone confirm?
