Ah yes. The 79' Eldorado Convertible I bought this past February with only 45K original miles on the odometer, I have temporarily named The Exxon Valdez.
Just finished rebuilding the steering box, R&R'd timing chain cover (installed Cloyes True Double Roller Timing Chain Set & Gears), R&R of oil pan gasket which required major disassembly and lifting the engine plus passenger side CV axle removal. New rear main bearing seal. New seals in the transmission. New radiator (4 row aluminum vs. 1 row stock), new water pump, new hoses, new fan belts. Plastic electrical switches dry out and crack and go bad. Complete through tune up, flush the fuel system. Replaced the power antenna motor. Clean the injectors, etc. Anything and everything that is in need of service and or repair is presently being done.
Car just 'sat' mostly for 36 years. Everything, once started and driven again, began to leak. Engine, Steering Box. Transmission, Coolant. You name it. Now, almost all has been sorted. Must finish replacing all front suspension bushings. That were dried out and cracked. Plus degrease clean and paint all components and seal them with satin clear coat over base paint as work progresses. Still need to install all new shocks and finish stripping and repainting + seal chassis underneath front to back.
 May install a new Magna Flow stainless dual exhaust system? Haven't decided yet as I also want to retain originality.
The good news? The car is very rare! Has a unique one prior owner history. Next to no mechanical wear. Is an original California Car (no rust). Is a gorgeous looking car. Paint, interior, top and wheels are either new or like new. In short, it is worth the work. At least it is to me.
