Low Oil Pressure at warm idle!
Johnny Vette
Brentwood California
2005 Crimson Pearl
Just curious. I have a 05 XLR with 47k miles always maintained, but at running temperature idle it is around 16-18 pounds. Is this normal for the Northstar or could I have a bad sender. On acceleration it goes right up to 50 pounds plus.
About right. The N* has surprisingly low oil pressure at idle.
I figured that was more than likely the case, Thanks for confirming that.
For your (and others) info, taken from my X:
Oil life at 65% left, normal operating temperature, correct oil fitted:
* At idle: 18-19, maybe 20
* At 1,000 rpm: 40
* At 2,500 rpm and higher: 60
Running slightly hotter than usual (heavy traffic stop/start), temp rising to 220
* At idle: 18
* Other rpms, same as above.
HTHs
* At 1,000 rpm: 40
* At idle: 18
HTHs[/QUOTE
That is pretty much where my car is. Feel much better about it now. Thanks for the info.
