- Joined
- Sep 2, 2013
- Messages
- 563
- Location
- Monument Colorado
- My XLR/V(s)
- 2006 Gold Mist XLR & 79' Eldorado Convert
Hi All,
As 05 Grand Daddy knows I had been painting and refinishing my truck. Base coat, clear coat. (Dark, "Majestic Blue Metallic") My issue and problem is as follows with the clear coat. Ugh.
When final buffing the driver's side rear door, I got too close to the door edge with the buffer, and Yup, "Zip" went through to the gray primer in a heart beat, on the edge. Dang! So, I sanded the surface and edge with #600 Grit wet, and laid down 4 new coats of base (color coat), let it dry and then 6 coats of new clear, Feathered the clear somewhat across the door to try to get it to blend in. Did not use a blending agent, or straight reducer to blend (probably should have?). Now cured and dry. One week ago.
Then I wet sanded the whole door with #1200 grit, then #2000 grit, then #3000 grit and started buffing. Shines like a mirror and looks good, except for "HAZING WHERE THE NEW CLEAR COAT ENDS AND THE OLD BEGINS".
Anyone have and suggestions on how to get rid of the hazing?
