josua
I've read all your threads on the Kenwood install and have one question I'm not sure about. I'm assuming the CD changer is not put back in the car? The Cd plugs are just tucked away after the jumpers are installed? If so, could I not get two plugs to match the Cd plugs and make the jumper connections on them so I could leave the factory harness intact? Also, the adapters used are wired according to the instructions that came with them? I'v put aftermarket units in two other Caddies I've owned with no hitches. The CD in the XLR is the fly in the ointment. The upgrade is mainly because the Nav in the stock unit is a piece of garbage, plus the other perks are great, touch screen, bigger screen blue tooth etc. One more thing, which Pac did you use, the SWI-RC or ASWC !? If you get a chance I'd appreciate the info.
