Steve Lee
What do they call the tool that is used to reprogram all the electronics?? It is inserted somewhere under the dash in the area where the HOOD OPENER IS.Can they be purchased? At what Cost? Where can they be purchased?
I've used original gm tech and the supposed knock of. Both work fine . You can get the aftermarket one for under 300. On eBay. I purchased both of mine from there. The port is beneath steering column. You will also need the gm card which is about $32.00What do they call the tool that is used to reprogram all the electronics?? It is inserted somewhere under the dash in the area where the HOOD OPENER IS.Can they be purchased? At what Cost? Where can they be purchased?
904-607-9264 mikeI've used original gm tech and the supposed knock of. Both work fine . You can get the aftermarket one for under 300. On eBay. I purchased both of mine from there. The port is beneath steering column. You will also need the gm card which is about $32.00
Ebay also. Still learning but have made good progress. Relearned top successful. One of the tricky ones. Call me if you like. I'm a junkie for this car.
