Help! Service Stabilitrak in the Morning
tonypro99
Newport, CA
2008 Red XLR-V
Hey all;
I seem to be having a issue with the Service Stabilitrak message coming on when I use my car in the early morning when the temperature is around 15 Celsius outside. As soon as I drive it for about 5 mins and shut off and restart the car it does not come on again?
When I don't use my car in the early morning but around 9-10am when the weather is 20-25 Celsius it does not come on???
So it appears to me be weather related but I don't know what to start looking at? Since I have had the comb installed in the Steering Wheel Sensor. If someone could help me out here that would be much appreciated!!!
I had a similar issue which, I believe, was battery related. A battery with low voltage can exhibit the same issue - maybe the battery volts drop enough when it's colder to cause the issue? Try using a Battery Tender at night and see if that "fixes" it.
PROBLEM SOLVED!
It turned out to be a weak battery which I gave it a charge last night and in the morning NO MESSAGE!!! I should have figured as much since last week I was working on the car changing the belt and had the hood open with the light on for about 5 hours continuous. Thx Very Much! :blinzel:
Glad that you found the problem, but keep an eye on your battery. The hood light normally will go out after 15 minutes or so.
:cool:
:cool:
Actually it never did the whole time which I thought was weird so I lowered the hood to make sure it was going out when I closed the hood, which indeed it was. Weird?!
