GM Press Release Squeaks
  • Thread starter Thread starter Wenabee
  • Start date Start date
W
Wenabee
I realize this is a tough question without hearing it, but here goes. I have a constant squeak coming from above the dash, so it seems. I'm thinking possible windshield gasket or where the roof contacts the top of the windshield,. I can't rule out the latter seeing the wind noise with top down covers up anything that might be the cause. Did anyone ever have a similar problem? TIA.
Similar situation, but it is not constant. Soon will clean the top/windshield pillar seal and treat with a rubber care product to see if that helps. If its coming from under the dash, then that may be more difficult to track down and eliminate?
Sometimes,,you just have to turn the radio volume up.
p z
p z
Thanks P Z, I'll try cleaning the pillar
