redsoxdad2
When I press the trunk button sometimes it will not open. It seems like it trying to open but doesn't open?
He advised this in post #3 aboveHi Redsox - did you solve this problem? Let me know - I have a possible solution or two, but want to check your status first.
Hope all is well!
Jay
So my trunk lid started a while back, opening about 4 inches then slamming shut again. Than it would open. Got worse, it would take 6 or 7 tries before it would open.
I replaced the trunk latch the other day (available from GM for about $350 or rockauto)
And it fixed the issue.
Not too hard to do, remove plastic trim. Two top plugs are covers and 7mm screws under them, 4 front plugs are just plastic push pins.
3 nuts on latch, 1 electric connector and manual unlock cable. About 10 min after you have done it once.
