redsoxdad2
My trunk opens when i activate any electrical device. So far it doesn't open when i am driving. Has anyone had this happen?
Sheer luck that I figured out the button was the problem. Now I ONLY use the fob to open the trunk.Thank You i never thought of that i will check that for sure.Try checking the trunk release button on the lower part of the dash, to see if it's popped back up all the way. When mine got stuck down a little sideways, the trunk would open every time I opened the driver door.Sheer luck that I figured out the button was the problem. Now I ONLY use the fob to open the trunk.
