Help! WIring schematic.
cobratoo22
Dallas Tx.
Howdy. Does anyone know of a source for a wiring schematic for a 2005 model. I did a search but could find none. My left front turn signal is getting no power to it and I'd like to trace the wire. It is a blue wire with a white stripe and I know it originates at the BCM in the passenger foot well. I'd like to know it's path from the BCM to the front of the car.
Thanks much.
I got this off of Chiltondiy.com
http://content.chiltonsonline.com/(S(il5g1t55km43fgmdzuz2w5jk))/content/images/GM/1254860.pdf
You probably have to have an account to see it. I’ve pasted an image below. A subscription is only about $26 per year. I use it regularly.
would you be so kind as to show the wiring for the mirror courtesy lights, that work with the doors??
Thank you for sending those diagrams, but I can't read any of the printing on them, it is very fuzzy. All of the wiring is easy to see, but not being able to read the print, even after enlarging them, makes them of no use.
Yeah, a one time use is $26.95??? Yes, that's a 1 year subscription, but I may not need it again.I have a work shop manual coming in the next few days, I'll wait and see what I can find in it. But, Thank you anyway!
Thanks much.
Did you ever get a response? My right turn signal quit working. I replaced the bulb, nothing. I tested the ground wire (blue with white stripe). It is good. But I am not sure where the hot side originates?
Did it quit front and rear? I believe each side has a fuse. Does the light come on just not blink? Ive seen a whole lot of turn signal switches sold new and used but ive never had the issue. Ill !ook for a diagram if you like
It only quit in the right front light. The rear still works. The dash readout says the signal is working at normal speed on both sides. I suspect an open wire in the cable, but not sure.
I bought a low budget Shop Manual for the XLRs for $20 on eBay a while ago. I has complete wiring diagrams for all model years of the car, including the V. It's not complete for all the components on the car but for $20 it was worth the investment.
Strange problem. If the bulb is out it will hyperflash. If there is a break in the circuit then you get an error message. Im thinking bad bulb or socket. If you unplug the harness see what happens is the drl burning? Same bulb different circuit
