Help! 2006 XLR
paulc17
Somers, NY
2006 Light Platinum XLR
Has anyone noticed two small marks on the hard top roof, equally spaced, one on each side. Well, I took the car to a body shop and they showed me where brackets on the underside of the trunk lid are making contact with the top of the roof (when it's folded down) and causing the marks.
The roof has to be repainted. I wonder if it's covered under warrentee.
Information
Document ID: 2202265
#PIC4547A: XLR Roof Does Not Latch At Rear Corners In Stowed Position - keywords latch loose mid open potentiometer retract stow trunk - (Oct 23, 2008)
Subject:XLR Roof Does Not Latch At Rear Corners In Stowed Position
Models:2004-2009 Cadillac XLR and V-Series
This PI was superseded to update model years. Please discard PIC4547.
Condition/Concern:
Some customers may comment of a mark in the paint on the roof panel. This mark may be on the drivers or passengers side of the roof and typically the size of a pencil eraser. Further inspection of the retractable roof may indicate when the roof is stowed, the rear corners of the roof are not secured in trunk area. This may be the result of a misadjusted roof panel.
Recommendation/Instructions:
  1. Lower roof into trunk as far as it will go. Stop when trunk starts to close. Check to see if the rear roof latches engage the lower support. Scribe the current position of the rear roof panel pivot bracket bolts. These marks may be needed if the panel moves more than needed. The position should only change about.5 mm (one half mm). Loosen both of the rear roof pivot brackets to rear roof panel fasteners one turn (both driver and passenger sides). These only need to be loose enough to allow the bracket to slide under the bolt shoulder. Do not allow the shims (if present) to become mis-positioned. Manually lower the panel so the rear latches engage and latch. Lightly bump/thump the rear corners of the roof panel above the latches using your open palm. Re-tighten the previously loosened fasteners to the specifications listed in S.I (Doc I.D. = 1739799)
  2. Cycle the roof and ensure that it latches properly in both the up position and down position with out assistance. If it does not latch in the up position the strikers can be adjusted.
(1) Front Of Vehicle
(2) Loosen One Turn
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION​
© 2009 General Motors Corporation. All rights reserved.
06 XLR "Marks on Roof"
Thanks. You nailed it!!
I will be visiting my dealer service dept. next week.
Do you know if they will re-paint the roof panel under warrantee??
Thanks again.
Paulc17
06 XLR Roof
Thanks again. I'll let you know how I make out.
Paulc17
06 XLR Roof Panel
My local Cadillac dealer corrected the roof problem and had it repainted. All under warrantee!
