Richiez
When I turn the A/C on it omits a “urine” odor. Has anyone experienced this and if so what was the remedy?
???? How is it going to know that the engine will be off for 45 minutes? Or,,, does it run after 45 minutes of shut off time?
Chad
It's 45 minutes after the engine has been shut off.
My wife's '06 had a musty smell from the A/C last year and it turned out to be the drain hose for the A/C was stopped up so the water was collecting in the passenger compartment. I had the dealer blow it out and the smell went away. I just checked my V and her XLR a couple of weeks ago to keep from having that problem again. So far, so good.
Does anybody have a picture of the drain hole?
You can have the Afterblow feature enabled with a Tech 2. This feature will dry the evaporator core after the A/C is shut off. Works really well.
Bruce,
Do you have a Tech 2 and if so, could you bring it to Bowling Green?
<form method="post" name="CellHandlerForm" action="/newsi/cellHandler.do">
Afterblow Enabling
</form>
- Turn ON the ignition, with the engine OFF.
I realize this is an old post, but I've been trying to get this to work on my 06. I have a TECHII but I need clarification on how to turn on the ignition with the engine off.
The only option I have is ACC on/off and either starting the engine or stopping. I can't figure out how to just turn on ignition.
Any advice? What am I doing wrong?
Press the start button twice without pressing the brake pedal.
