gulflyer
I own a 2004 XLR which I purchased about 2 years ago. A few weeks ago I started getting a constant Stabilitrack caution light and shortly thereafter an ABS caution light. I drove the car very infrequently after that, waiting for a good time to take it to the dealer when the right window failed to go up all the way after putting the top back up. The window would go up maybe halfway, stop, then go back down. I took the car to the local Cadillac dealer (Sam Taylor Cadillac, Ft Walton Beach, FL ) to have the problems fixed. I was told the computer(s) for the Stabilitrac and ABS had an internal short and would have to be replaced and the window motor/ regulator for the right window would have to be replaced. Total bill around $2200. They made the repairs and I picked up the car. 2 days later the radio/nav system won't power up and then slews into the open position exposing the DVD slot and stays there. A day after that I try to roll up the left window and it freezes at about the half way mark and won't roll all the way up. Unbelievable. I take the car back to the dealer and the service dept says they don't know what's wrong with the radio/nav system and that I need a window motor/regulator for the left side and should consider buying a new radio. Who knows how much they would charge me for that work. Now I have to think something happened when the initial repair was made; ie when replacing the computers and other work that was done involving the electrical system. As I understand the XLR electrical system, everything runs through the same data bus. My question is this : Is it possible that something was done by the mechanic that inadvertently caused the later problems with radio/ nav and then the window? By the way - the fuse for the radio is good - it was the first thing I checked.
