Steve Lee
The Cadillac dealer said my brake fluid was turning yellow, and needed to be changed. I worked as a mechanic for about 10 years, and the only reason to do that was because at the time, brake fluid was glycerine and alchohol, which absorbed water, making it neccessary to flush the system, and replenish it. Now they use DOT 5?, and whatever # it is, it is silicone. Does silicone turn yellow with age? Does it need to be changed when it does? What DOT number should be used??
Do I have to, or should I use, Mobil 5/30 in my 2005 XLR? There are a few other very good motor oils out there, one I can think of is valvoline. Castrol, and Pennzoil are also very good. I just purchased the car with 26,800 miles on it. If I wereto use Mobil which one? Sythentic?? or just regular old oil?
