I am about to pull the trigger on ordering new wheels and though I had it nailed down until a call told me that someone had given me some incorrect information. At least they called!
For those of you who have done the upgrade, what is your wheel size including offset? I am getting different stories from vendors. I've ordered the tires 255/45-18 and 285/35-19. on front I can either go 8.5 or 9.5 width if it does not stick outside the fender with an 53 or 56 mm offset. I am thinking an 8.5 with a 53 should clear the caliper and provide the best inside clearance.
On the rear I was hoping to use a 10" wide 19" with a 79mm offset to keep things under the fender. This puts the outer lip within .04" of stock. I may need to re-think that and move to a 56mm offset to allow for 4 piston calipers in the future. The 56mm offset puts the front lip of the wheel almost 1" further out than stock. Maybe a 79mm offset and custom fit spacers? It is easier to grind a spacer than to grind a wheel.
Thoughts? Advice? What have others done with the brake upgrades?
