CC, I just wanted to follow up with you regarding the problem that I "was" having with the car intermittently shutting off in the middle of driving. You suggested that I replace the ignition switch which I did 2 weeks ago now. And dude, I have not had one instance of this problem reoccurring. I am not going to count my chickens just yet because I have had instances where the car went for many days (probably not 2 weeks though) where the problem did not occur so I am not yet completely comfortable with saying it is resolved but so far so good. If this truly proves to be the solution, I cannot thank you enough for the suggestion. As my posts have indicated, several dealers and two mechanics had no clue what the issue was without it reading out some computer code. No longer do I drive the car in constant fear of when it will out of nowhere simply go into "accessory mode" and turn off and I have you to thank for that. YOU ARE DA MAN!!!!!!!!!!!!!! Take care and thanks again.Rather than place the ignition switch on a shaker table and test it for continuity while simulating road bumps, I'd just replace the switch first since it's available and inexpensive. After that, you're looking for loose connections in the ignition circuit.
CC
