Hood lift supports ..........Just frustrated
Bill S.
Jensen Beach, FL
Hey
So I'm getting my oil changed on Monday. I'm off; it's a holiday. My hood supports are original and no longer do the job, as of about July 15. So I look at Rock Auto and buy the Hood lifts for an '06 V . ( Strong Arm Lift supports packaging says 6241) not a big deal . They arrive, but I received two different lift supports....different lengths.
Strong Arm Lift support 46241 G-A
Strong Arm Lift support 46241 T-A
Contact Rock Auto; they say send them both back and they'll send the correct ones out. I do and they send me two lift supports. They are both package labeled 6241, just like the last two. These two are identical lengths though.
Unbelievably I think they are wrong AGAIN. The OEM GM supports I am replacing are configured with the black cylinder at the bottom (body side) with the hood up and the chrome shaft up toward the hood side. The ones I got will fit, but the black cylinders are up by the hood side, the chrome shafts down connected to the car body. Seems upside down to me, but that is the way they fit.
What do you all think ?? Is this acceptable ?? Have never seen hood supports configured like this.
Trying to avoid the embarrassment of the broomstick oil change, but guess I got to suck it up and deal with it.
Bill
You are right,, most cars have their hood struts installed in the reverse order, chrome shaft down --- BUT...BUT,
20130914164712 - YouTube
^ > Hood strut install direction on XLR > 20130914164712 - YouTube
^ > I'm not promoting the use of the shaft 'stops' displayed in this video. Video for view example only.
From 10 to 20 years ago in the auto parts business, I would never recommend STRONG ARM hood struts made by Arvin-Meritor Corp. as they seemed to
be always weak and didn't last a long time. Maybe they have improved their lift struts in the recent years, but I can't confirm that.
Personally, I would order the following struts:
MADE BY STABILUS FITS THE HOOD | SG130099
SKU: SG130099-W | MANUFACTURER: STABILUS
$24.90 Each V V V
Cadillac aftermarket parts | Explore Lift Supports Depot Now
1-866-969-5438 Call to verify your needs and ask questions
Hey Zen
Hey thanks..... I've been google image checking and that, I guess, is the new way for installing the lift supports. I'm just over this whole thing and will just install the ones I got.
As a side note.... I had an '83 Eldorado touring coupe and had a variation to the clamp method that the guy used in that video. When the hood supports went in the Eldo, I took the support out of the driver's side and drilled a hole through the shaft ..... attached a ring pin to a small chain and that solved the issue. I thoroughly explained the manner for hood support and how it worked to the guy I sold it two a few years later. Within a month he forgot or something and put a kink in the hood. Really had to have ignored the resistance to have done that . Oh well.
Bill
Hood struts
Bill.
The struts for the hood purchased could be of the after market ones with a different concept that could fit the same but differently.
I have purchased in the past some after market struts that were fitting like the OEM.with the cylinder downward as per the photo
Enclosed is an XLR with the hood opened showing the OEM one installed and the after market ones that i purchased few years ago.... their push on clips fittings were the sames as the OEM, with no problem of installation.
IAN :wave:
Hey
Bill
Paint the broom handle black.
