rexster314
- Joined
- Oct 2, 2015
- Messages
- 1,556
- Location
- West Columbia, Texas
- My XLR/V(s)
- 2006 Base Infrared (SOLD)
Curious, do you have a clear bra on the front?
Oops, washer caps should have gone on while the front fascia was off the car. Hard to get them on now, or it was in my case.
The spray nozzle are mounted prior to installing the front fascia. The "caps" are mounted after the fascia is on the car (press & turn). The caps are old and sometimes they break when removing them prior to painting. My old caps one of them broke and it's best (IMO) to use double adhesive tape. Otherwise, you'll have to paint the caps and pray that they don't fall off.
I purchased a pair of 2009 XLR side fender vents. They should add a bit of "pop" to my 2007 XLR.
I think you have to cut into the fender to get these to fit on anything except an 09???? Would like to hear your findings as I like this too.
Pretty sure the factory vents require some cutting of the panels. The ones I've seen on eBay looks like they're just stick on, but can't tell for sure. I go back and forth about getting them myself
According to the seller the fender vents are "stick-on." Granted, I don't think GM made a special fenders for a part, but I will see next week.
The fender vents do not require any cutting to the fender. They have been talked about before and members putting them on. The reason for them is to cover a blemish in the fenders themselves. If you look very carefully on any model about a inch or two forward of the door/fender gap there's a ripple going up and down the fender. They didn't want to change the fender molds. These vents covered the flaw.![]()
Well, hopefully tomorrow I'll get to drop by the shop and put to rest the issue regarding the side vents. Either way, the shop can handle the problem (if there is such a problem). I'm just looking forward in seeing the car back together again, but with new front and rear fascia plus hood
