Bakertech
Passenger Door Release Switch only works sometimes!
Anyone have repair info?
Thanks.
Thanks.
YIKES!!! Ok, I have the in/lb's torque wrench, trim removal tool and will procure the 28 bottle case of 5% Budweiser. (My reply was 2 Buds).This points heavily toward the switch being bad, or an intermittent connection in its path to its door control module.
Having a Tech 2 would make isolating the cause a five-minutes job, but since you don't, you'll need to take the door trim panel off and measure the operation of the Door Latch Release Switch with a multi-meter to prove the part is actually bad, then replace it, and put the whole thing back together. You'll need beer and trim removal tools to do this job, plus the usual hand tools, and an in/lb-capable torque wrench.
Because it's a fairly simple job requiring no power tools or exposure to lethal voltages, it's recommended to break out the higher octane micro-brew for this occasion. If it isn't going to be fun, why bother?
The procedure to remove the trim panel can be found here:power window passenger side
(This may seem like a superfluous, common-sense caution, but I'll put it out there anyway: Before any electrical connections are broken or joined, ensure the ignition is placed in the OFF position. I hate it when I get PMs from people who accomplish the jobs using procedures I write but fail to follow safety precautions I take for granted and weld their fillings together.)
1. Once the door panel is removed, remove the inner energy absorber from the door panel.
2. Remove the four fasteners from the rear of the armrest.
3. Remove the single fastener from the front (forward-facing end) of the armrest.
4. Disconnect the armrest wiring harness and remove the armrest assembly.
5. Remove the armrest pull trim cover - pull on it to disengage the retainers.
6. Remove the retaining screws from the metal trim cover applique.
7. Remove the applique from the armrest.
8. Remove the screws retaining the Door Latch Release Switch from the armrest trim cover applique.
To test the Passenger Door switch, measure between Pin 3 (Gnd) and Pins 1 (Open) while pressing the switch.
Reassemble the pile of stuff sitting in front of you in reverse order, paying particular attention to the steps where beer intake is most appropriate to accomplish the job in a timely manner. For me, this is an invitation to embibe at each step, but your mileage may vary. Personally, I like to get a head-start early in the morning. In case something else invariably goes wrong, I have the rest of the day to sober up and determine whether it's more practical to remain sober or give up altogether.
Other technical things to note during reassembly:
1. Torque the Door Latch Release Switch retaining screws on the trim cover applique to 17 in/lbs.
2. Torque the (five) screws securing the armrest to the door panel to 89 in/lbs.
CC![]()
Had someone push the open button on my passenger door a little to hard this weekend, and it pushed out. I read CCClarke's instructions on how to replace the button if it goes bad and the part number. Is there anything else I would need to order before I take the door apart that would "seat" the button in place?
Thanks.
![011- door-lock-hardware-front-6y1000301[1].jpg 011- door-lock-hardware-front-6y1000301[1].jpg](https://www.xlr-net.com/forums/data/attachments/5/5106-0c595c7279deb203e6baee07f2808e7b.jpg?hash=DFlccnnesg)
![image1[2].jpg image1[2].jpg](https://www.xlr-net.com/forums/data/attachments/5/5107-fa8fbe606f73c56eb01dca2101e4fa46.jpg?hash=-o--YG9zxW)
![15934397-cadillac-xlr-passenger-seat-rh-roll-bar-hoop-loop-headrest-ebony-platinum-3[1].jpg 15934397-cadillac-xlr-passenger-seat-rh-roll-bar-hoop-loop-headrest-ebony-platinum-3[1].jpg](https://www.xlr-net.com/forums/data/attachments/5/5108-d7f4464f6c443c9668139f84ccf39459.jpg?hash=1_RGT2xEPJ)
