Jaxrwild
When making a left hand turn sounds like a grinding noise, put it up on the lift didn't see anything visible, any suggestions???? More like tire rubbing on plastic
that do they look likefor a little small rubber they can make a lot of noise when turning. I second the check on the spring adjuster . Other than a look at the plastic shields to make sure they are not rubbing which would be obvious shiny spots on them I would look at the spring adjusters.
I have a 2006they are a round rubber on the ends of the leaf spring under the control arm. if the rubber is flat and mushy or missing it will make noise when turning . these are for lowering but you can get stock ones
1997-2004 Corvette Bolt Kit Lowering Front 25-321054-1 | eBay
