Roof Seal cleaner and lubrication, to keep from drying out
Jaxrwild
North Carolina
2006 Light Platinum
what is everybody using on your roof seals to clean and keep them lubricated so they don't get dried out?
Cleaning: I’ve seen APC recommended. I’ve just used waterless wash and a microfiber cloth, along with a Qtip for tight spots, to gently rub & clean it (at least for spots that just washing the car won’t reach).
Lubricant: GM recommends, & I’ve seen others use both for XLR’s & other hard top convertibles, Dielectric Silicone Grease. I haven’t tried that but have tried several other products, all of which ran down when the car was washed & made a potentially staining mess on the paint. My go to now is Zaino tire gloss. It usually doesn’t run down (except when I overdid it once), & even if it does I know it won’t stain the paint, plus I can get it off with quick detailer (washing alone may not do it). It has UV protectants & doesn’t attract dirt, dust etc.
My 2 cents ...
Gummi Pflege Stift. Been using it on BMW for years .excellent product. I like the tube so you put it on a rag and gently work it into the rubbers. Keeps them soft and full If yo uuse spray., spray on a clean rag and wipe it in so you do not overload the seal. Two or three easy applications better than one heavy
thanks
