HOMEGAMEROOM
- Joined
- Oct 16, 2008
- Messages
- 1,253
- Location
- Georgia
- My XLR/V(s)
- 2004 Light Platinum, President, "Midwest Marauders"
I think it's supposed to be relatively nice outside today - maybe it's time to blow the cobwebs out of the XLR!
Some members have had some issues with their cars that, had they had advance notice of the issue, could have been averted. A good "Spring Cleaning" of your car could help. here's one:
There is a little drain tube in the tub that holds the pump and brains for the folding top mechanism. Crawl under the car and make sure the drain tube is not blocked! If it fills up with dead bugs or gets sealed shut with road debris the area around the pump can fill with water, which will result in the failure of the pump. This is a very costly and avoidable repair!
I also like to give the seals for the roof and trunk a good cleaning and lubrication with silicone. This eliminates many squeaks that can occur and gets rid of any dirt that can scratch the mating surfaces.
Check the fluids, check the belts & hoses, change the oil (if it needs it), give it a good wax job, and you're ready to roll!!!
Does anyone else have anything to add that they think is a "must-do" maintenance item?
