Using a Tech 2, can you do things like command the headlight washers to operate without having to use the button control in the car?
I know that this is off topic, but I have never been able to get those washers to work. I think they are just for show.
The following is from the owners manual:
Windshield Washer
K(Washer Fluid): The lever on the right side of the
steering column also controls the windshield washer.
There is a button at the end of the lever. To spray
washer fluid on the windshield, press the button and
hold it. The washer will spray until you release the
button. The wipers will continue to clear the window for
about six seconds after the button is released and
then stop or return to your preset speed.
Your vehicle also has headlamp washers. Every fourth
time the washer fluid button is pressed, washer fluid
will clean the headlamps.
The Tech 2 can do a lot of things, but I don't know if it will do what you're asking. I'll hook mine up this weekend to the V and see if I find anything for you.
