Just ordered the Corsa Exhaust yesterday. Can't wait to have it installed.
BTW, while he was installing the Corsa, i had him install the rear sway bar. Haven't driven it enough to know if it was worth it, but for $150, looked like an obvious upgrade.
The exhaust system looks great! Adding the sway bar at the same time was a no brainer! Where did you purchase the sway bar from?
Zeek,
Pasting a link to a post by DanF, post #10. He has all the parts listed and a link to gmpartscenter.com. I bought mine at www.gmpartsdirect.com for about $150. This is the sway bar for the V, but fits our car as they are the same frame. You need to look at the specs on the bolts that thread directly into the frame, though. The ones they sent me didn't fit, but were easy to find locally. The description was correct, but still didn't fit.
https://www.xlr-net.com/forums/cadi...ussion/7080-sway-bar-post51264.html#post51264
Zeek,
Thanks for the response, it looks great. The cab noise is my concern, I did not want an annoying drone at cruising speed.
Interesting discussions.
Personally, I wonder what the V would sound like with a different exhaust. Some time ago, I did install the mild to wild switch (the control module is in the truck unlike the vette)
now the sound is nice, not quite " V8 ish" IMHO, and is subject to highway drone as mentioned above...and the ability to turn off is nice...
but, has any1 tried the V exhaust approach with something other than stock mufflers" that will work with the pneumatic valves?
As Phrede stated, Billy Boat makes a system for both the XLR-V's and Corvettes with the dual mode exhaust. It is their Fusion system. I installed it on my V and use it in conjunction with the Mild 2 Wild switch. It is louder than stock with the baffles closed and very loud with the baffles open. With the top up and baffles open, there is 'drone' at cruising speeds.
