XLR-V to LT4 Drivetrain Swap _ FTC
Mad_Trbo
Dallas
XLR/V
Hello All.
I've been on quite the odyssey, swapping the tired LC3 drivetrain out for an LT-4 drivetrain. I ended up using the LT-4 drivetrain out of a 2019 Z06 corvette which created some complications due to different communication protocols used between the various modules. Class -2 J1850 and lo speed CAN on the XLR and GMLAN hi speed and lo speed CAN on the Vette.
The car went to the vendor with the top fully operational and I have no reason to believe it's still not still operational. We just can't get the top module to wake up. I believe it's because messages that use to come from the XLR's ECM / TCM into the BCM are no longer there to be translated and sent by Class-2 protocol to the folding top module. That along with some other missing interdependencies and checks the top requires for safe operation.
I am hoping I can pull on the heart strings of our curious community and ask a favor. Can a tech 2 user with a working top cycle through the process of closing and opening the top and datalog the process and send me the file. This will allow me to see the exact communication pattern between the BCM and folding top module.
have a look at work performed to date at the following link.
Sold the entire drive train on Ebay some time ago.
Is there anyone in Dallas with an XLR and a working folding top module willing to let me log the operation.
You could take a close up look at the swap, aesthetically the vendor did an amazing job.
Hello All.
Wow!
Crazy and amazing work being done to that XLR!
Should be very unique for sure!
Would hate to see the bill though, especially from a "TV Show Shop" !
I will stick with my Classic cars, I can work on them myself and much less complicated. Stick to just driving my XLR.
Good luck, show us finished product!
I've purchased a Tech II, and just need to figure out how to use it. Might be several days, but I've been able to see data from different modules.
Hello All.
Hello All.
I used this technique with the Tech II. Worked on my 2008.
I was able to record logs, but I can't figure out how to get them from the "tech 2" to my computer. I can tell you that you will need to figure out how to tell your BCM & Roof Modules two things:
1) Engine Running
2) Trans in Park
I'll do a bit more research on these, and try again on getting logs from the tech2win.
