Cadillac Tech
Make sure and check the A/C evaporator drain tube on your XLR. If the tube gets pinched or restricted, water can drain into the car @ the passenger side footwell area & damage things like the BCM and inside fuse panel. On a humid day with the A/C on, you should see water dripping out from under the passenger side of the car. The drain tube can be cleared with a long blow gun & small amount of compressed air... be gentle, you don't want to blow the evaporator out of the car.
